I am newer to owning a pool and need to replace my pump.
Will add details on my pool below after the lead in and question. Apologize if there is too much detail with the question lead in.
I have a Pentair Easy Touch 4 with Screenlogic2, and need to add a new pump. The original is an old Pentair single speed which will not operate my Zodiac MX8 Elite Vacuum Robot, and the skimmers.
The pump my research has brought me to is the Pentair Intelliflo 3hp VS+SVRS primarily because I THINK it will integrate to the automation in a way that would be beneficial.
This initial pump replacement is a phase one to get my pool back to proper operating condition. Phase 2, this fall, will be adding a second pump and a cartridge filter for the spa. For now one pump runs it all.
Question:
1. Based on my pool setup below is this pump sufficient to operate my vacuum robot and two skimmers at the same time? (Single speed it is one or the other)
2. Can I set the varying schedules below using my phone app? I currently use the app to set schedules...though the app itself is a bit glitchy when adding multiple schedules.
3. Can I use my automation to set up different schedules that will allow me to customize multiple applications?
The different schedules I would like are:
1. High flow for Vacuum & Skimmers (or just the spa) to run based on a set schedule
2. Low flow to run on a set different set schedule
3. Med flow to run the skimmers and two waterfalls.
Pool Configuration:
- Kidney shaped pool
- 20k gallon chlorine; 4' to 7.5' deep, 2 - skimmers, Vacuum inlet, Main Drain
- Approx. 600 gallon raised SPA approx 6 jets and is farthest from pool equipment
- 2 - Waterfalls, approximately 3' above ground
- Pool equipment around 25' from start of pool and nearest skimmer
- Length of the pool continues straight away from pool equipment
Equipment
- Individual 2" PVC piping for each feature above that go to a feed manifold as well as a return manifold
- Jandy valves with electric actuators, SPA, Waterfalls, and SPA air pump (To have a low air to the jets setting)
- Inline chlorinator
- Pentair check valves for spa, spa filler, and between heater and chlorinator
- Hayward DE Filter
- Old Hayward Natural Gas Heater - H300ED1
Question:
Pool Configuration:
Equipment
- Hayward DE Filter
