Hello everyone,
I wanted to share an update with you all. After a series of disappointments with my pool service company, I made the decision to part ways with them. The level of service I received did not align with the price I was paying, so I've taken the plunge and will be attempting to manage the pool maintenance myself.
In my latest efforts, I utilized my TF-Pro kit to test the pool water, yielding the following results:
- pH: 8.2
- Chlorine (CL): 0
- Chlorine Drop Test: 0
- Total Alkalinity (TA): 120
- Cyanuric Acid (CYA): 40
Upon inputting these readings into Pool Math, I encountered a bit of confusion regarding the next steps:
1. Free Chlorine: I'm uncertain whether the SLAM toggle should be turned on or off. Additionally, what would be the appropriate "Target Free Chlorine" value?
2. Total Alkalinity (TA): It seems my TA is on the higher side. Any advice on addressing this?
3. pH: Should I prioritize adjusting the pH now, or is it wiser to first address FC/TA and then tackle the pH?
Concerned about the absence of Free Chlorine, I decided to take action by adding 1 gallon of 10% Chlorinating Liquid I purchased from Walmart.
I hope that I haven't made any significant errors in this process. Any insights or suggestions would be greatly appreciated. With a bit of guidance, I'm confident I can successfully manage the pool upkeep on my own. Thank you all in advance for your assistance.
Few details:
14k gal pool
chlorine pool
cartridge filters
single speed pump
- pH: 8.2
- Chlorine (CL): 0
Few details:
14k gal pool
chlorine pool
cartridge filters
single speed pump
