Hey all! I’ve been reading through various other threads and I have a theory but want some input before moving on.
My friends have an inground, vinyl lined pool. They don’t know exact volume but the estimate is 40,000 gallons. (It’s a little bigger than mine which is 35,500). Anyway they’ve been “managing” their own chemicals for the pas couple of years using the Clorox dichlor shock packs. They have a test kit but it only tests pH and chlorine.
The other day they asked me to help, bc it was not looking right. I tested yesterday (using my TF test kits stuff) and these are the results:
FC 1.5
TA 0 (turned pink with R-08)
pH bright yellow (what I read online said that if the TA is zero then pH is likely no higher than 4.8)
CYA 100
I used the pool math calculator and told them what to put in the pool to bring it up to SLAM and raise the PH and TA.
This morning they texted and said the pool turned dark green and cloudy - it was relatively clear yesterday even though the chemicals were bonkers.
I just tested and these are the results
FC 45
pH HIGH (8.2)
TA 100
CYA 100
I read that if there is iron in the pool it willl oxidize and turn green. I know in the past they’ve had to add ascorbic acid to clear metal. Do they need to add that now? Or just wait and let the SLAM finish? It is not clear green. Pic attached.
Also, do they need to bring the pH DOWN or just wait until the pool is clear to allow time for it to settle?
I don’t want to tell them the wrong thing!
Thanks for helping if you’ve made it this far!
FC 1.5
CYA 100
FC 45
pH HIGH (8.2)
TA 100
CYA 100
