- May 3, 2014
- 58,691
- Fiberglass
- Pentair Intellichlor IC-40
The Overnight Chlorine Loss Test is to check if you have organics consuming FC. If you lose 1 ppm FC or more overnight, it is best to follow the SLAM Process
Tomorrow morning test your FC. Add enough to get to 6 ppm . That is the low end of your target range. I would prefer you add to 8 ppm FC until you see how your water reacts. You do not want to let your FC go below 4 ppm.
