TFP has a different methodology than what the pool store teaches you.So you completely ignore the FC level of 1 to 3ppm, as is promulgated just about everywhere on the Planet Earth except here.....? Instead of trying to keep it "exactly right," you deliberately get it up high, then after it declines to 1 or 2, you raise it back up again....
Also, we do not put FC at 11ppm and let it drop to 1ppm. There are minimum levels of FC based on the CYA level of the water.
You mentioned in the original post you are trying to determine the cost to maintain your new pool. If you follow the pool store philosophy I can assure you they will convince you to use algaecides and other potions that will cost much more in the long run.
TFP provides an effective and proven way to maintain your pool at the lowest cost.
