LONG EXPLANATION:
So I've been trying to open the pool for over a month now. When I removed the cover, the water was green. I shocked the pool and then cleared up a little bit, but then a day or so after, it seemed to have turned green again. Two weeks of balancing and shocking, but nothing seems to clear up the algae. I also tried algeacide specifically for yellow\black algae followed up 10 pounds of shock (normally 2-3 is enough to clear up the pool), but still nothing.
Deciding to raise the white flag on killing the algae, I decided to just drain the pool rather than continue to dump $ and chemicals into it. I was using the Main Drain to empty out the pool, and got it to about 85% empty. I shut it off for the night because I didn't want the pump to run dry. Next morning, I can't get the pump running from the Main Drain to drain the remaining 15% of the pool. I don't necessarily want to fill the pool back up again with the remaining 15% of muck as it will basically bring me back to square one.
Things I've tried:
1) I tried priming the vacuum and skimmer, but it doesn't maintain its seal\pressure with the water level so low.
2) I tried priming the main drain line, but doesn't seem to get the pump going when started.
3) I tried blowing air into the main drain line from the pump but don't seem any bubbles coming out of the deep end.
4) I can't see the actual drain at the bottom of the pool because it is so murky. I used the pool brush in its general vicinity to move any possible debris/blockage.
Questions:
1) Does the main drain need a specific water level to work? or at least get started?
2) Any other options? I have a standalone water pump, but it is fairly small and will take forever to empty the pool and possibly burn itself out.
Things I've tried:
Questions:
