I have read the posts related to GFCI issues, but have a slightly different issue. I replaced a wet end on a Watkins Jet Pump on Hot Tub due to a leak. All went well and was working fine for about a month. Then every other day the GFIC would trip (never when we were in it with everything running or on Cleaning mode). Usually it just trips when circulating every day or so. I was wondering if anyone thinks it may be a bit of corrosion from the old leaking wet end getting into motor? However was working fine for a month after putting it on. I tightened all connection to be sure nothing was loose or burnt. Then I unplugged components separately to test all one at a time. Narrowed it down to this #1 jet pump. It would only trip (still only once a day) when this pump was connected. Never trips inside breaker, just the outdoor GFCI. It works perfectly other than sporadic trip. Ideas on what it may be? And....If it is was a little corrosion, can anything be done to try to remedy this instead of the costly replacement? Any thoughts, ideas or suggestions are much appreciated!
