- May 3, 2007
- 18,095
- Plaster
- Hayward Aqua Rite (T-15)
Then the flow rate numbers are meaningless when you put the cleaner on. Flow rates change with head loss.Calibration was done at full speed WITHOUT cleaner attached. All the flow is going to skimmer. I have a simple set-up. Old pool. The main drain plumbs to the single skimmer (I have that closed off), and the skimmer goes straight into the pump, no valves. no heater, no solar. nothing really adjustable.
From the picture above, the return head loss is 45' and the flow rate is 56 GPM. Why did you use 60 GPM? Also, did you include the fittings underground and the return eyeballs? Also, every filter has different head loss characteristics so you really can't use fixed value for that. It is also dependent on flow rates.I was hoping I could pick your brain on two fronts:
1. Measuring my return lines and guessing at the fittings, I get a return equivalent length of 135 Ft of 1.5 pipe, Suction equivalent length is 42 ft of 1.5 pipe.
On the return side, at 60 GPM, that translates into 27 ft of head, Adding 3 Ft for the sand filter (I read that is a good enough approximation), I get at an experimentally estimated 30 Ft of head for the return side. The Pump Spreadsheet calculates at 39.4 ft. Could the difference be evidence of a blockage? I haven't tried the drain king but a hose and shop vac have not helped.
At lower speeds, the pump cannot create as much suction as higher speeds so the pump lid can probably seal that very well. Also, a pump lid will have different sealing characteristic under different pressures. So you could have a leak on high and not on low or even visa versa.2. One thing I cannot understand is when the pump is on low speed, I can completely close off the suction line (with a plug in the skimmer), and it does not cause any air in the pump basket. Initially, I thought this confirmed that I did not have a suction air leak but now I am not sure. Shouldn't the basket evacuate?
