Hi
I've been following the TFP forum for a year now, and up until now it's been really easy to achieve crystal clear pool water.
I've recently opened my pool for the summer and i'm having trouble getting the water clear. I've run the full range of tests with a clearchoice test kit, and the levels all appear to be good.
The problem is the water has a lot of suspended particles, and there is a layer of brown dust sitting on the floor of the pool and on the steps.
Whenever I vacuum the pool it stirs the dust up, and then after a couple of hours it settles back on the bottom of the pool.
Does anyone have any ideas here?
Should I do a SLAM? My CC has always been 0, so i've never had the inclination to SLAM. But maybe it's worth a try.
I'm thinking I might just have to do better at vacuuming, and run the filtration system for longer.
I am currently running the pump for 8 hours a day.
The readings taken with the clearchoicelabs test kit are:
FC 6
CC 0
pH 7.4
TA 60
CH 170
CYA 50 (but I will be increasing this to 70 asap)
Salt 3500
Any help or suggestions would be greatly appreciated!
FC 6
CC 0
pH 7.4
TA 60
CH 170
Salt 3500
