Hello - I'm struggling installing an Intermatic PE733P. I have filter pump + booster pump + pump (controlling water fall). When powered up mode "manual" lights "yellow". Pressing mode goes to "service" with red light. Pressing mode goes back to "manual" where it stays solid yellow. Load (red) lines set to "Com 1", "Com 2", "Com 3." Black wires to "NO 1", "NO 2", "NO 3." AC lines attached to L1/L2.
Per Intermatic's online video you're to hold the mode button to turn on network light to complete the setup process in the app - no joy. I tried manually powering each circuit, they light green but no power. I removed a functioning PE1353ME and put tape on wires before disconnecting. In that application, all black wires went to "Timer Power 120v or 240v" with jumpers to each circuit line. I'm at a loss...not sure if my rudimentary electrical skills are biting me in the keester and/or if I've got a defective pool timer. I've attached a photo of PE733P + wiring diagram + PE1353ME (before I removed). I'd appreciate any insights. Thanks!
