- Aug 22, 2017
- 2,598
- Plaster
- Hayward Aqua Rite (T-15)
So the Tristar VS pump plus the Omni automation bundle is on sale at the local PinchaPenny. Including the rebate from Hayward I can get the whole thing including installation for about $2000 (without the valve actuators). Since it is installed by one of their dealers it will come with a 4 year warranty.
The automation will control my heater which is Hayward. Turn my SWG on and off. It will also run 2 actuators.
Here is the problem, I need 4 actuators, but I don’t need them to run independently. When I turn on one of the actuators I don’t mind if two go in the same direction. So in theory I can double up.
Will the board be able to drive two actuators from the same port or will that be too much of a load. I could have the port also fire off another relay with a separate power supply but them I am just a few steps from building my own automation system anyway. It would be awesome if I could just splice 2 together and be done with it.
2K is cheap enough (with a pretty good VS pump) where I don’t have to bother making a whole DIY automation system (which would have been fun to do, but a lot of my time).
