My 4 year old motor, Hayward Super Pump, started tripping the gfi circuit breaker after a heavy rain. After trying to diagnose issue I discovered that it only tripped in the morning startup but after the Sun came out it would be fine. I thought the problem was that the motor got really wet and moisture in morning was the problem. I since covered the motor only and it was working fine but I got rain last night and it tripped this morning. My power stays on up to the switch so the problem is from switch to motor. Can wet exterior wire to motor be causing a short. Stumped
