Hi TFP community!
This is my first time posting in this forum.
I am a recently new homeowner of a house that has a pool. Its been 2 years now, the pool has been working good up until recently. I had some landscaping done to build a retaining wall and didn't know where the in-ground pipes were installed; I found out the hard way that most of the pipe was installed around the concrete patio surrounding the pool. However, the landscapers had broken an underground pipe; they quickly replaced it and let me know about it, and I thought all was good until I decided to open up the pool and start up the pump. The pump doesn't draw water as fast as it pumps it out, so the basket level is pretty low, or you see that gushing effect of water coming in and getting pumped out quickly. I used a snake and endoscopic cam and found a significant amount of air in the newly repaired section of pipe.
I have a few questions:
- What's the general practice for removing trapped air in a suction line?
- Is there a recommended pressure test kit or equipment people can recommend? I saw some fancy nice ones but they cost an arm and a leg.. maybe I just need the right plugs or valves? I've dug up most the lines and I don't have any problem working with the PVC. I think it would be wise to see if my pipes can hold pressure.
- Does anybody add sanitary tees to their pool lines? It seems like it would make it easy to snake and see what's going on inside the pipe or to remove blockages if the need ever came up. (Although between the skimmer and the pump doesn't seem like a lot of opportunity for large debris to get sucked into the line.. but its possible.)
- What's the guidance on plumbing suction lines, do they always want to slope up from the pool to the above ground pool equipment pad, or would level pipes be fine? The repaired section of pipe looks like an upside down U, which is why air is stuck in their blocking the line. I'm trying to figure out if I'll just want to re-do that section of the line, or if the pipe was full of water, would suction be good again. (And if the latter, how to remove that air and get the pipe filled up with water)
Please don't refer me to pool professionals.. I think with the right knowledge and tools I should be able to get this fixed, I just need some guidance.
Thanks in advance for any help!
