Thanks BoDarville. Results of last night's OCLT: PM FC = 20.5, AM FC = 20. Yeah!!!!
You were right, that definitely wasn't as painful as the CYA test!
This afternoon test results: FC = 11.5, CC = .5, TC = 12.0, CH = 250, TA = 180, Ph = 7.8.
So it looks like everything but TA is inline. Ph may not be accurate due to the high chlorine levels. I will keep an eye on Ph when chlorine level goes down and if it spins out of control I will adjust TA down.
I think we're "in the clear" for now anyway! Correct me if I'm wrong. Thanks so much for your assistance! Hopefully our chlorine usage will decrease now!
PS - I will be reading up on the pool pump now - it will be nice to get our pump time down and save on electicity!
So I was reading
http://www.troublefreepool.com/content/152-determine-pump-run-time
(about determining pump run time), and it says "There are several objectives for pump run time. First, it is very important to add chlorine to the pool in order to reach FC targets. For BBB pool owners, this can amount to only 30 minutes of run time while adding chlorine for distribution....Next, studies have shown that a typical pool really only needs about 4 hours of run time for proper chlorination, circulation and cleaning. So our recommendation is to start off with 4 hours of run time if your pump is single speed ... then gradually increase the pump run time until it is clean enough for your own tastes. "
So why increase from 4 hours if it is possible to get down to 1/2 hour. Should I increase or decrease as desired, rather than decrease?
For now, I put the timer on 4 hours to start tomorrow. I'll keep it that way for a week if everything looks good. Already if this seems sufficient that will be cutting our summer run time in half!
