I would like to be able to track the salt levels I get from the Taylor drop test and what my Pentair IC60 reports. They are 800+ ppm apart at times. Currently the drop test consistently shows 2,800 and the SWG reports 3,450. The PoolMath gives the warning that my salt is outside the recommended range. Earlier this year before I turned rhe SWG on I raised the salt level to 3,600 based on the drop test. The SWG reported that the salt level was too high and it would not generate chlorine. I posted this in the SWG topic a couple of months ago. The suggestion is that my flow switch & sensor could be bad, but given the replacement cost it might not be worth it, if it still worked.
If they were tracked separately I could know both when my SWG was happy and get a better insight into the actual salt level.
