Hi all I've been trying to help a friend' with his newly built pool .He has a problem with what I'm guessing is calcium scaling .He has had flat plate like build up on his chlorinator cell almost over night.
The cell is self cleaning so can just be washed out between the fins but there is a lot .So have turned it off for the time being .Have been using 10% liquid chlorine to sanitise the pool .Have also started using trichlor to get some cya into the pool as I am unable to buy it on its own where we live out in the sticks of Thailand .
The problem seems to be that the bore hole fill water has a TA of 270plus .I have managed to drop it down to 180 so far by adding HCL letting the pH rise which it is doing quickly then adding more HCL .
The concern is how is the pool going be maintained and balanced with the fill water being so high .The only thing I could think of is maybe a 2000L standalone tank and try to lower the TA before it goes into the pool .
Also the calcium hardness is only 100.So that needs raising as well Any suggestions welcome
FC 3.0
PH 7.5
TA 180
CH 100
CYA 10
FC 3.0
PH 7.5
TA 180
CH 100
CYA 10
