- Jan 4, 2013
- 56
- Plaster
- CircuPool RJ-60 Plus
Hello all!
Quick background. I'm ready to replace my existing pump and I've decided on the Pentair VSF line for (mostly) obvious reasons. My current setup uses a single Jandy PlusHP 2hp single speed model. It's a PHPM2.0 which is their Max line having a service factor of 1.13 for a Total HP of 2.25hp. This one pump runs both my pool and spa with about 26,000 gallons total. According to nameplate data, it consumes 2688 watts for 10 plus hours a day! That's 26.9 KWh per day! And my bill reflects it in the summer! My main reason for upgrading is the electrical use. From reading around on the forum it seems a common speed for VS pump users is around 1300 rpm which is around 650 watts. That would be around 6.5 KWh per day versus the 26.9 currently. Dramatic difference! As I understand it, buying a new VS pump should pay for itself in about 2 years. Works for me!
So, onto my options. First, the Pentair website is confusing. For the VSF pumps it seems I have 4 options that all have the same motor (3.9 THP), are similar in price ($1,035-$1,090 quick web search) but have WEF's (watt efficiency factor - Energy Star Rating, higher is better) that vary from 5.6 to 7.5. I assume this is due to differences in the wet end which would be contrary to what I've read elsewhere on here that the wet ends are all the same for the VSF models. I don't know, nor can I find supporting documentation about any differences.
So, here are the model numbers:
011056 IntelliFlo VSF (I believe this is the replacement for the well known 011018, but not sure)
022056 IntelliFloXF VSF
011059 IntelliFlo i1
011060 IntelliFlo i2
Can anyone help explain the differences and maybe which pump would be best suited (and why) for my purposes please?
Thank you all in advance!
Dave
Jandy pump curves attached. 2nd curve from the top.
Dave
