Hello Guys. Been a lurker here for a few months and learned A LOT. Did my first OCLT last night and ended up with a loss of 2ppm FC (8 hours total). Pool looks great, was suspecting a potential issue when I had to turn my SWG up past 95%, running pump for 19 hours with a break at night for the water to settle and dolphin to do a full clean. Pump schedule is as follows. I am running an electric heat pump set at 86.
0730-0800- 3000 rpm to stir after off cycle.
0800-1645- 20 GPMmin To make flow switches on heater and SWG
1645-1715- 3000 rpm to stir before and during water guru automated reading (reference only while I’m traveling for work)
1715-0300- 20 GPM for flow switches
0300-0730- pump off for debris to settle (2 hrs) and cleaning cycle (2.5 hrs)
Dolphin starts at 0500 for a 2.5 hr clean.
I am SW Florida and am in direct sunlight most of the day. CYA should be between 50 and 70. I’ve read the standard for an OCLT is a max loss of 1ppm. Does simply being over 1ppm automatically mean I have to slam? CC is less than 0.2. Yesterday I added 2lbs CYA to get from 50 to around 68 I’m expecting, and added 2 hours of hose water to account for evaporation (heater set at 86). Also yesterday we swam with the kids, do almost every day. Why I’m hesitant to slam if I don’t need to. Really looking forward to some responses as I’ve read some great threads here. Thanks!
