We're going on our 4th season with our above ground pool and it has been mostly great. The Intex SWG has worked fairly well, but the life of the electrodes has been short. Even though it says it is rated for 15k gallons, I have to run it for 7 or so hours per day during the summer to keep the chlorine up. The electrodes need to be soaked in acid frequently to clean, so I started having a second one on hand so I can just swap them back and forth. I've had to replace the main one several times ($125 each), and the secondary one once ($62.50 each), as they eventually just stop making chlorine and/or throw low salt errors.
Between the constant maintenance and the cost of replacing the electrodes, I'm feeling like it might be worth investing in a higher quality system. I'd rather stay under $1k, which seems reasonable given the small size of the pool. I've googled and found some options, like this: CircuPool SJ-20 Saltwater Chlorinator | Discount Salt Pool
but would love to get input from actual pool folks. Thanks!
