The timer for my pool is not rotating. The visible gear at the top is not rotating either. I can manually turn the timer on and the pump runs fine.
The timer is hooked up to a 220v breaker. Since the pump works fine, I kind of assume that the timer needs to be replaced. Any specific things I should know to fix, replace it? (Besides being careful around the 220v!).
![timer 1.jpg timer 1.jpg](https://www.troublefreepool.com/data/attachments/71/71917-246b5eed2a12d6ced70dd21dcf15570e.jpg)
![timer 3.jpg timer 3.jpg](https://www.troublefreepool.com/data/attachments/71/71918-8e19b4feaf494827d4e5fa848f1405a8.jpg)
![timer 2.jpg timer 2.jpg](https://www.troublefreepool.com/data/attachments/71/71919-308fd0d576d35efe51856951019e3ac5.jpg)
