Hello experts, I would appreciate any troubleshooting advice or suggestions you may have about my puzzle. I’m into my 3rd year owning an in ground pool from my parents’ property, installed 1990’s. Water flow when pump is energized is failing as follows.
Water flow: skimmer —-> gravity drain to 2 year old Hayward 1HP pump —> multiport valve —> Sand filter —> Chlorine puck cylinder —> return jet.
The multiport valve and sand filter are original 1990s vintage. I replaced the spider gasket last season. I did this because I could hear a foreign noise from the multiport valve, as if there were sand knocking about when under flow. Changing the spider gasket did not make any difference. I still hear this noise. While the multiport value was off the filter, I rinsed out the sand according to TFP video. I repeated this process this season.
My issue is that when the pump is energized, it is very slow to prime. Once primed, water flow seems normal (except for the multiport noise). I see bubbles in the return line.
When power it turned off to the pump, there is a significant “pressure exhaust” sound from the system and water releases backstream to the skimmer, lifting off the skimmer cover.
The multiport valve settings do seem to work as expected, i.e. filter, backwash, rinse, waste all seem to work as expected.
As I mentioned the pump is below grade of the skimmer. When open to air, water drains naturally from pool to pump, if open to air. but when closed to air, water will flow only when the pump is on, as expected. The problem is that when energized, the water does NOT flow, or hardly at all, for several minutes. The problem has become worse and I won’t allow the pump to work on timer anymore, for fear of burning out the motor for lack of water flow.
My guess is there is something in the multiport valve or filter that is resistant to water flow. I see no obvious obstruction and the sand seemed “normal” but dirty when I cleaned it this year. I wondered if the seal between the multiport valve and the sand filter pipe is leaky. I can disassemble this for a third time but I”m not sure what to look for. To test my theory, I tried running the system on “recirculate,” thinking that any issue with sand filter would be bypassed and system would run normal. Unfortunately, it seemed to make no difference. Still fails to prime as expected.
Since the filter and multiport valve are > 20 years old I’m fine with replacing them. I just wanted to get some reassurance from you that this is the right move, or if there is anything else I should try to be sure. Apologize for the lengthy post. Let me know what other info I can provide. Thanks so much for any comments or suggestions// John Bednarski
