Tile repair advice
Melnic
0
217
Maryland
Ok
Winter was not good for my tile at the waterline. Last year I had about 10 tiles to replace (put back on). I used ezpatch as they were below the water line or across it. I had tapped on the tile all the way around the pool and on an outside bend had some hollow areas. Well 1 week after opening they started to fall off. I think I have about 30 2” tiles to replace at, above and below the water line. I am debating draining water or not. Refilling is the painful part as I am on well water and it will take almost all day to put that water back. I’m leaning towards not dumping water so I can take my time on the tile and stretch the work out over a week or two.
Any suggestions?
