Has anyone done this - successfully?
I installed the typical Intex floating basket skimmer. It has great potential, EXCEPT: It doesn't work while the kids are swimming because it gets knocked all to heck and the basket comes out. I know that the instructions say not to use it while swimming, but I wanted to see the result. Now I know.
The kids swim off and on all day. That leaves the night available EXCEPT: I always have a solar cover on the pool at night. Also, my overly-sensitive neighbor doesn't want to hear the pump on at night. My bedroom is closer to the pump than his and I can't even hear it when on. Go figure.
Therefore, I either have to avoid using a skimmer at all, or figure out some hack for a smallish thru-wall skimmer. I know that will be a challenge both because there is no doubler in the pool wall for that purpose and because the wall is not stiff enough to support the weight of an external skimmer.
If you have successfully done a hack like this, I'd love to hear how you did it. Pictures would be awesome. If nobody responds to this, then I may just experiment with it myself and post back here with my results. I figure I'll do the following:
1. Use extra vinyl pieces with vinyl adhesive to create inner and outer doublers.
2. Buy the smallest wall-skimmer I can find.
3. Install the skimmer through the new doubler and sandwich the gasket on both sides with a helping of vinyl adhesive that will squish down and squeeze out.
4. Install a pvc support up from the ground on the outside to support the skimmer without making it TOO rigid.
5. My system is hard plumbed, so I can connect a hose from the bottom of the skimmer into the pvc on the outside.
Your thoughts on this? I'd appreciate any advice you have!
