Still in progress of renovation remediation and pool water will have to come out for next phase. Yesterday we noticed that the NEW granite coping stone over the deep end skimmer has a crack in it. We will have a new stone cut and would like thoughts on how to reinstall the 12 x 24 x 1.5" granite stone. Any ideas on why this may have happened and how to prevent it from happening again? The stone was set in Platinum 254 and Permacolor Grout between stones. You can see the grout has hairline crack which may speak to movement and / or expansion - contraction. Should we use a soft joint material like Latasil instead of the grout next time to allow for movement? What are your thoughts on having a bridge across the skimmer opening when the stone is removed to replace it? Thank you for your thoughts Pictures below.
