Hi, TFP crew. Shortened pool season this year, late start for various reasons, but I took it from swamp to clear with a 4-day SLAM and endless leaf raking from the depths. I am determined to open to a clean pool next year.
I've never closed a pool, and this setup which we inherited is relatively complex. I hope my pool photo album and descriptions load properly so you can make out what I'm dealing with. After reading through the various extensive threads on closing, I understand the basic process. I could use some guidance on specifics related to my pool, especially the blowout. So here's my starting point/plan, and follow-up questions:
1. Optimize chemistries, bring to shock level (not planning to use polyquat), drop the water level below the skimmers (why not also below the returns?)
2. Remove eyeballs from all returns
3. Decompress/drain filter and remove cartridge at this point?
4. Blowout. I'm still confused on this, and I have several circuits to deal with. The easiest method is a shop vac at the skimmer (?), and the water goes... where? All the way through the pump, empty filter shell (plug replaced), heater (no drain plug), and back to the returns, which I can presumably plug up one by one? And do this through each skimmer separately and pop in a gizzmo afterwards?
5. Blowout, #2. Small pipe to booster pump, not sure how to handle. Could close all outflow valves to pool and spa returns, maybe? And then there are the bubbler and two spa pump circuits to deal with. Actually, the bubbler circuit is 100% air. Should I try blowing out directly from each pump before disconnecting them? Or just remove the pumps and blow out inflow and outflow lines one by one? How to achieve a decent seal?
6. Blowout, #3. I understand that clearing the main drain line can be a challenge.
7. Blowout, #4. Waste line. Bypass filter with valve and blow from skimmer to street?
8. Blowout, #5. I saw a video where someone was vacuuming directly from skimmers into a shop vac? I don't see anyone here recommending this.
9. I'm already losing my train of thought. If anyone can direct me through the proper sequence here, or if you gently suggest that I let the pros handle it, any feedback appreciated. Thanks as always!
