After 2 years of a perfect pool following the help on this forum, the past week or so my pool as not been able to get that crystal clear water that I usually have. I have bumped up the chlorinator, but still not change (actually the water maybe a bit worse) - so something must have gotten started growing in the pool - it was a very hot couple of weeks and lots of use, so that would definitely be apart of it.
So I am thinking I need to do a SLAM . Question is, in the SLAM directions it says CYA should be be 30-40, but since my is at 70 (which the recommend level for my pool with a SWG) do I need to get that lower before I start, or will I be ok to go head?
Here are my test results from yesterday
FC 6
CC 0
pH 7.5
TA 70
CH 125
CYA 70
Salt 4000
Water temp 86
Thanks for the help
FC 6
CC 0
pH 7.5
TA 70
CH 125
CYA 70
Salt 4000
Water temp 86
Thanks for the help
