Noticed a large drop of water 4” over the last few days only in my pool section, spa has stayed normal evaporation drop. Decided to let the level drop until it stopped and it appears to level out just below the skimmer levels.
Doing some research it appears it could be leaking from the skimmer to pool connection or through the suction piping back to the pump. I tried the dye test but it really didn’t show anything. When I run the pump with the water level full the pump has no issue holding prime and has actually held prime ever since I have started to let the pool water drop below the skimmer.
There is still a level of water in the skimmers and it’s holding at a constant level. Would all of this indicate more of a leak from where the pool meets the skimmer rather than the suction piping from the skimmer?
Thanks for the help
Thanks for the help
