- Jun 12, 2011
- 3,767
- Plaster
- Pureline Crystal Pure 60,000
ptbrunet said:Curious to know: does pH of 7.3-7.8 not raise TA, while pH 7.0-7.2 lowers it?
Just to be clear the addition of MA to lower pH also lowers the TA. Everything that raises pH also raises TA, with one exception....aeration. It does it by off-gassing. And it works best if you maintain a low pH. Even if you don't actively aerate, but do maintain a lower pH (7.0-7.2) you will have some off-gassing that will slowly raise pH, without raising the TA. So over time if you maintain lower pH the TA will go down. But no, high pH will not cause the TA to go up, it will result in scale forming if you have high CH and will keep the TA from going down, since the off-gassing only happens at lower pH. So you need to maintain a lower pH until the desired TA is reached. Aeration just speeds up the process.
