Hello all, new member here. Been lurking for a few months. Great to see this helpful community, hopefully I'll be able to contribute back.
Some background.... My tub is an Arctic 2021 model with the built in SWCG and Ozone, 275 Gal/ 1041 litres. Bought new and still under warranty. Went through the new owner issues such as test strips, water balance confusion compounded by the tubs probe needing recalibration, rash, tub needing multiple purges....
Now fast forward a year I have the Taylor K-2006, a digital scale and am able to move the waters parameters precisely. The issue I'm having is that when the tub is running with the air on, people in it or not, the PH will rise from a 7.4 to 8+ in about ~15 minutes.
-4 days ago -routine Ahh-some purge (just a bit of crud) Rinse and wipe out- new fill.
- Fresh water (City - somewhat green colour) fill readings;
PH 8.0
FCL 0
CCl 0
TA 30
CH 30
Temp 67 F
Added 15 grams Dichlor
Added 92 grams Calcium
Added 120 grams Sodium Bicarb
Added 20.5 grams Sodium Bisulphate
Added 5.1 Pounds Salt (2000ppm-2500ppm recommended )
New filters.
Next morning Clear water;
PH 7.6
FCL 7.6
CCL 0
TA 70
CH 80
Salt 2260 ppm
Temp 99F
Seems all good...
Combined over the next three days;
Added 30 grams Sodium Bisulphate
Added 3 grams Dichlor
Use of 2 people 1 hour
One day later to today;
Tub reads PH high warning which happens at 8.0, So I test and its 7.8( I have to get them to come and calibrate again) but decide to drop it to 7.4 to get rid of the warning. I added 10 grams of Sodium Bisulphate turned on the jets and off again in five minutes PH at 7.4. Decided to run the jets with the air on to see the PH rise and in 10 minutes it was back to PH 8.0. I then had to add another 10 grams of Sodium Bisulphate to bring it back down.
Is there something I'm missing?? Does everyones PH rise this quickly when using the jets?? Almost every time the tub is used, acid is needed unless starting PH is 7.0-7.2.
Present test results;
PH 7.4
FCL 1.2
CCL <0.2
TA 50
Temp 98F
Cheers.
PH 8.0
FCL 0
CCl 0
TA 30
CH 30
Temp 67 F
New filters.
PH 7.6
FCL 7.6
CCL 0
TA 70
CH 80
Salt 2260 ppm
Temp 99F
Seems all good...
PH 7.4
FCL 1.2
CCL <0.2
TA 50
Temp 98F
Cheers.
