SquireEstate
2
Ridgely, Maryland
Stats:
33,000 gallon vinyl in ground pool
Sand filter - new sand as of May 2024
Located Eastern Shore of MD
Last summer, we brought our pool back to life after it had sat for years with the previous home owners. Compared to this summer, it was easy.
The pool was uncovered over the winter. We began to clear it in the beginning of May and after initially shocking it with liquid chlorine, water quickly went from swamp green to cloudy teal. We used 4 gallons of the liquid shock over a 2 day period. An employee at the pool store told me I did not need to keep shocking and we could balance it. So we did. A few days later, the pool is green again. Green like we never touched it.
I told the pool store and they said the employee should have never told me to stop shocking it. So they had me get more shock. Nothing could bring the pool back. We tried more shock and also tried Yellow Out and Swamp Treat. Nothing. Finally the pool store suggested HTH Green to Blue. This was the only thing that finally worked. Pool was back to blue but very cloudy. The store told me to add Clarifier - it did nothing. At that point the pool was perfectly balanced except it could not hold chlorine.
We had a birthday party so the pool was shocked Friday, Saturday, and Sunday (day after the party). Pool looked ok except for the cloudiness. By Thursday it started to look a little green so I went to the pool store Friday and got more shock and they told me to use Pool First Aid to get rid of the cloudiness since it won’t hold chlorine. By Friday at 7 PM, the pool was back to grass green. As green as the very beginning before I touched it. I put 4 gallons of shock in Friday night and Saturday morning it looked the same. I did not do the Pool First Aid. I brought another water sample to the store due to concerns of ammonia. Ammonia test was negative. Phosphates and Nitrates are also not the issue.
Yesterday they told me to shock with 2 gallons and then 1 hour later use Dual Action Algaecide (3/4 of the gallon). They said 12 hours later it should be cloudy and I would be able to then add the Pool First Aid.
This morning the pool is basically the same. It is disgusting and I am ready to close it for the summer. I have spent weeks fighting it and was able to get 2 days of swimming out of it. Hundreds of dollars in chemicals and the pool looks like it has never been touched.
In summary:
•Last three water tests the water is balance but chlorine is low
•Tested for phosphates, ammonia, and nitrates and they are not the issue
•The pool was vacuumed and all debris removed before the party on 6/15.
•Only things that have worked is the Green to Blue and constant shock. But we cannot determine why it won’t hold a chlorine level.
•Pump is working, backwashes dirty water.
•Our liner is old and faded so pool won’t ever look beautiful blue.
Why won’t the chlorine level stay elevated enough to prevent it from turning green? I shocked with 3 lbs granular on 6/14, 2 lbs 6/15, and 3 lbs 6/16 and by Thursday 6/20 it started to turn green. The pool store told me the last thing we can do is send my water to a bio lab for testing.
IMG_8161.jpegIMG_8162.jpegIMG_8159.jpegIMG_8160.jpegIMG_8156.jpegIMG_8155.jpegIMG_8154.jpegIMG_8165.jpegIMG_8166.jpeg
Welcome to TFP! :wave: You obviously have algae, and everything the pool store has done, said, and sold you is making it worse. That's the simple truth.
Algae requires a process we call SLAM - SLAM Process. To do that process you must have a proper test kit. That is priority #1. Local free testing is horrible so don't bother. We recommend ether a TF-100, TF-Pro Series, or Taylor K-2006C kit. See the links below for a good kit and we can get you through any chemistry issue.
we are worried about constant high levels of shock. Any thoughts on this?
The chlorine won't make a difference in that regard. In fact, it's probably that much more important to clear the algae ASAP so that you can see what you're working with in there. The SLAM Process is completely different than what you have experienced with pool store guidance. The FC is tailored to the CYA for safe conditions but also optimal sanitation. Swimmers can even be in the water during the SLAM. But you must have one of those test kits for accurate numbers. It all hinges on that first.
Until that time, I would add 1-2 gallons of liquid chlorine to the water each day until the kit arrives. Don't add anything else. Some of that pool store gunk can make matters worse on the water and filter.
Welcome to the forum!
The sad part is it appears you were happy with the water quality at your pool party time. From the pictures, it was so cloudy it was likely unsafe. You will be amazed what water should look like.
I suggest you read through Pool Care Basics - Trouble Free Pool and even look at a few of our videos TFP-TV - Trouble Free Pool
