I closed the pool with CYA at 33 last year. I have often opened to 0 CYA, but not this year ...
This year, when I tested the water at opening, it was not clear (so, not 0). But, it was also not cloudy enough to read the lowest number on my Taylor test kit, which is 30. So, the number is somewhere between 1 and 29.
With this weird range of 1 - 29ppm of CYA, I really have no idea how to figure out the right amount of CYA to add. All of the threads on TFP about adding CYA assume that you're able to figure out how much CYA is in your pool.
Is there any way to figure out the CYA in this situation?
This is a real problem with all of the test kits! As TFP members, aren't most of us aiming for CYA in the 30-40 range? The tests go so much higher than needed for people with that goal, and leave the most important range out by not enabling a reading from 1 - 30 (or 1 - 20 on some kits).
I could guess at my number, but let's say I guess 5 and it's really 25. My CYA would wind up 20ppm more than ideal. Complicating the situation further is the issue of CYA not showing up on test results for a week ...
Right now, I'm thinking I should guess 15, add that amount, and wait a week to test again. Does this seem reasonable? Is there another way?
