I started my first SLAM on my pool yesterday. The pool was cloudy and it seemed to have sand in it. There is a lot of sand in the yard. I now believe it is mustard algae.
Here are the starting test results:
June 29 7 pm
FC 15 (I had turned the SWG up being in denial of needing to slam)
Cc .5
Ph 7.6
TA 90
CH 300
CYA 50
Salt 3000 (SWG is off)
I also back flushed the sand filter and the pressure is staying consistent at 8
So I added enough bleach to slam target of 20 ppm
9 PM last night (After brushing the pool and vacuuming with the Dolphin)
Fc 20
Cc .5
Cya 50
At 8 am I went out to the pool and saw 'yellow' stuff in several areas of the pool. So i brushed the pool and took a chlorine reading fc of 18.5. I used pool math and added the recommended chlorine. I vacuumed the pool again with the dolphin.
I again tested at about 1230 and here are the results.
Fc 19
Cc just slightly pink
Cya 50
Should I be testing for anything else during the SLAM? I believe I read concentrate on FC readings.
I am getting ready to brush and vacuum again. And take readings also.
A couple of questions regarding the Dolphin, my brush and skimmer etc. How do you recommend cleaning them to make sure I don't contaminate the pool as I go along ths process.
I have read so much my head is spinning. If I need to make adjustments, please let me know.
June 29 7 pm
Cc .5
Ph 7.6
TA 90
CH 300
CYA 50
Fc 20
Cc .5
Cya 50
Fc 19
Cya 50
