As I am re-learning all of the water chemistry after years without a pool, I am happy to see all of the technology to assist with keeping track of tests and recommended amounts of the required agents to get water balanced. My question is this; If I use the Leslie's or Pinch a Penny app, or if I go in-store for a test, their recommended levels are somewhat different than the PoolMath app.
Pool store PoolMath My last test 6/8
FC 1.0 - 4.0 4.0 - 9.0 7.5
TA 80 - 120 50 - 90 95
pH 7.4 - 7.6 7.2 - 8.0 7.5
CYA 30 - 100 30 - 60 54
CH 200-400 250-650 240 - added 4 lb Hardness+
The recommended FC in PoolMath is so high that the other apps recommend I don't swim. My CC is 0. I added 1 bag of shock+ on Saturday afternoon because we got a ton of rain, which continued all weekend. Before shock FC was 1.8. I have a Nature2 express, which is about 3 weeks post install, so my goal is to lower the chorine and CYA. I have an inline chlorinator, which is currently turned off. The reason I went with a Nature2 is that I had a Vision system on my last pool (1999-2004) and loved the soft feel of the water. After reading a bunch on here over the last several days, maybe I shouldn't have added it, but none the less it's installed now.
Bottom line is I want to get it right and I am open to any suggestions from the experts, but I really need to understand why there are such discrepancies with some of the recommended levels between the 2 above.
Thank you!!
Thank you!!
