I use a SWG generator (low salt) and it has a list of recommendations for levels on the first page of the PDF:
Should I use the TFP recommendations or the recommendations from the SWG manual? I have a vinyl lined pool. Hayward is recommending CYA 20-30 and the TFP app recommends different ideal ranges for example.
Also, of topic, but related to testing/balancing water, can you use pool chemicals in the spa? Online on many websites it says not to, but mostly they seem to be the same chemicals.
Thanks
Thanks
