- Jul 4, 2012
- 749
- Vinyl
- CircuPool RJ-60 Plus
Good morning all, I suspect lots of new members this weekend with the unofficial kick off of summer, especially for those of us in the North.
I soft opened my pool last weekend, pulled cover off, relubed all the gaskets got plumbing hooked up to get circulation going, water clear, tested FC at 10 still - 11th year in a row opening with TFP methods, clear water and plenty of FC.
A week later though my water just doesn't quite have TFP sparkle, but it's definitely clear. (I just tossed in the Dolphin to get good pic, I don't typically run it with lid open!)
That's about 4 feet of water. Maybe my eyes are playing tricks on me. I have a "TFP clear" test which is sit underwater w back to the wall, mask on and I should be able to clearly see the details of the stone pattern on the other side. Did that test (after a jog, cold water!) and still after a week of circulation I wasn't seeing the stone pattern 30 feet away.
Well, it's only been a week, ducks have been making daily visits... but still. FC consumption has been only 1-2 daily the past week and it's never fallen below 6 (opened to cya of 40, now raised to 60ish) so nothing going on there.
Maybe my cartridge filter is wearing out, or maybe I accidentally put in the old back up that I've kept around for 8 years without ever using? Filter pressure hasn't moved much....
Open it up and.... mystery solved! Mind you, I lubed the O ring and lubed the lock ring (amazing hack I read here many years ago, I used to have to use a rubber mallet to loosen it) and was very deliberate in checking all the connections/unions, and yet somehow did not put the filter cartridge in!
So after a week with no filter media my pool was still objectively clear using TFP methods! Good reminder for me to make a donation.
Running pump on high so should have my TFP sparkle back in a day or so.
Happy Memorial Day weekend TFP!
Paul
Paul
