I have been caring for my new pool for about 8 months now , using the Taylor test kit and following the TFP chemical guidelines . Learning as I go . Here are a few questions I have about chemical ranges .
When a range is provided such as Calcium Hardness 350-550 for a pool with SWG how do I know where in that range is best for me ? Should I be at the low end of that range , middle or high ?
Same goes for TA. How do I know where in the range I should be of 60-80 or is anywhere ok? If I get a reading of 50 does that mean I need to act and bump up to 60 or is that 10 difference ok . I see it bounce between 50 and 60 frequently.
With regard to PH . I struggle with PH as the SWG tends to make it on the higher side. ( drives me crazy ) On the Talyor test kit the highest on the thing you put the test water in is 8.0 and bright pink . How do I know if I test 8.0 bright pink the PH is not actually higher as it stops at 8.0? When I get the bright pink I log it as only 8.0 and use the Pool Math app to tell me what to add. Is there a way to know if it is actually higher than 8.0?
When I test for chlorine I use the FAS DPD test and then test for cc. Is there a need to use the other TC test ?
Looking forward to your feedback !
Jennifer
Jennifer
