- Aug 31, 2018
- 36
- Plaster
- Jandy Aquapure 1400
Both test the same. The FAS-DPD can test to 50 ppm. Not sure why Taylor says that. It is not correct.
The TF100 is designed for the residential pool owner. So you have more of what you will use and less of what you will rarely use (like CH tests).
Get the Speedstir too - makes testing much easier.
We wanna make you work a little harder to reach that 3k post mark! I've seen that too when I respond again fairly quickly.Not sure why this combined my comments into one response when I responded at different times.
You can order just the FAS/DPD test kit, FAS/DPD Chlorine CC's test.
I just finished researching Taylor's website and the FAS/DPD test states it is only good for 20ppm of FC and 50ppm of bromine. I have tested FC over 30ppm so I'm not sure if the test is considered to be accurate or what. This will need to be looked into so we can get this cleared up..
