Thanks, I will then drain and replace >5000 gallons in the next couple of days which should get my CYA to < 70. After that will address the low PH, high TA and low CH.
Your welcome and sounds like a good plan.
Sure, but if it were me, I would work up to a higher level to see how I did.
Pump sucking air was due I believe to the diverter in the skimmer beginning to leak at a high rate (likely needs new o'rings - will address later).
In that case, could you block off the skimmer input so that air couldn't come in? Maybe a rubber ball or something small enough to get in the right spot to stop airflow, but strong and large enough to not get sucked down the pipe? Just thinking of a way to overcome the diverted issue.
Happy you passed OLCT last night. Are you going to do it again tonight? I did mine twice just to be sure. It you pass it again and the water is crystal clear then you are done. You only have to keep FC at the recommended range.
As you recommended it, I will. I'm pretty sure it will pass but you can never get too much practice/data with the test kit. The pool is looking as clear as I can remember it every looking.
BTW - I read your thread and have to say you did a great job staying on top of your SLAM especially given all your extra activities.
Thanks. I really needed to get it done. Now I am waiting on one more thing and we can have our home inspection for foster to adopt. Hoping to have another little girl in our home by the end of the year.
That's great, based on your drive and persistence as evidenced in your thread, you have nothing to worry about. Our children are grown and living in Denver, New York and Atlanta. Our kids are now our 4 year old Boxer Lab rescue (a gift when our son moved to Denver a couple of years ago) and our new child, a 7 month old Black Lab whose every bit as trying as a 7 year old.
From where you are, I would let the CH cycle up naturally. If anything, I wouldn't take it above 250. Conversely, you could use a little Cal-Hypo once in a while as well. Your low CH makeup gives you some options I wish I had. Very nice!
