- Dec 14, 2021
- 288
- Plaster
- Pentair Intellichlor IC-60
I do like the speed stir. Just wasn't sure it was worth the extra $.The TF-ProSalt comes with the salt test and the speed stir device. Nothing else is needed then. With a great box.
The TF-100 lets you add those if you choose, the box isn't the same as the Pro version which is a negative
Maddie![]()
I was crunching the numbers to justify the added cost. Seems like the TF-Pro Salt w/Smart Stir is the way to go.You need the salt test ($25) that use the Taylor reagents. You WANT the Smart Stir. I couldn't imagine testing without it ($44). You're up to $152. You'll want a new box to hole everything (+/-$20). Just get the TF-Pro Pro Salt with Smart Stir ($170). You won't regret it.
