Hi guys, I’m going to buy the ft100 for my new saltwater pool. There are a bunch of optional add ons. Do I need the saltwater add on? Are any of the others recommended?
Somehow, you need to get over $100 for free shipping. Most people would recommend the TF-100 along with one of the salt test kit options. The lower priced option has smaller reagent bottles. You may want to opt for the XL option and I would highly recommend the Magnetic Speedstir.
The TF-100 salt test ($19) is the same test as the Taylor K-1766 without the extra box, etc.
Either is a good add-on that you will want.
I also agree that the SpeedStir makes the testing easier and perhaps more accurate.
I was going off memory but just went to the site to confirm.
[FONT="]4. ...The Taylor K-1766 reagents R-0718 and R-0630 come in 0.75 oz sizes and the TF-100 Salt Test R-0718 and R-0630 comes in 0.5 ounce sizes. They are all Taylor reagents[/FONT]
Agree that 1/2 oz in more than enough. The R-0718 you only use 1 drop per test and the R-0630 you will use about 15 drops per test ... so that would be about 20 tests before you run out of the 2nd reagent.
Now that I have the kit, what other supplies/ingredients should I buy to make the necessary adjustments when it tells me something is off. Where to buy those?
So my pool builder just turned over the pool to me for care. They gave me these and gave a weekly schedule for adding these. Also want me to add 6-7 chlorine pucks per week. Are any of these useful if I’m using the tf100 kit and TFP methods? If not, what basic ingredients do I need to buy in order to make adjustments based on test results?
700 sqft +100 sqft sun shelf + 50 sqft spa. //// Jandy ePump 2.7 HP //// Jandy aquapure 1400 SWG /// Wet Edge pearl matrix jet black //// waterfall with single speed pump //// JXI 400 propane heat /// aqualink RS automation
I have DE filter. He said to put that stuff in the skimmer after every backwash.
I’m not sure if I have metal in my water. I do have hard well water.
Everyone keeps saying to just keep this and that under control and I’m fine. But how do I keep These readings under control? What ingredients do I need for adjusting levels?
