Ok skimmer hooked up again. Had to put a heavy rock in it to hold it down. Kept sliding off side as it bracket would change positions.
Whatever works! Keep SLAM'ing!
If you had say, 10 FC at that time, no biggie, and you'll likely need more this morning depending on the load. You keep on like you are and this will get done in a reasonable time.
Great, you are doing this like it should be done. Keep hitting it without fail as you have. Good Job.![]()
Call the meeting folks and tell them you are in the middle of a critical SLAM, and you can't make it.![]()
That's way more important. You have enough feel for what you'll use while gone now. Just don't go overboard with a touch extra to hold you over.
