Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more…
www.troublefreepool.com
The safest way to ensure you have enough Free Chlorine for your CYA level is to round up your CYA result. If the endpoint of the CYA test is between 50ppm and 60ppm record that result as 60ppm and use that to determine your required Free Chlorine level.
