TF-100 Help With CYA Test
The safest way to ensure you have enough Free Chlorine for your CYA level is to round up your CYA result. If the endpoint of the CYA test is between 50ppm and 60ppm record that result as 60ppm and use that to determine your required Free Chlorine level.
