I have a FC of 12 or higher always because of CYA at 100. How do I test PH if the FC level invalidates the test? Thank you.No issues. As long as you do not need to test pH. A FC of 10 ppm or greater invalidates the pH test.
You have to get the CYA lower, or take your chances by letting the FC drop below 10.I have a FC of 12 or higher always because of CYA at 100. How do I test PH if the FC level invalidates the test? Thank you.
Yes, I did it the first time, and it was at 100, so I read the forum and did it again at 50% (50% pool water and 50% tap water) and then multiply by 2 and it was again 100.You have to get the CYA lower, or take your chances by letting the FC drop below 10.
The best choice is to lower CYA.
Have you conducted a diluted CYA test to prove it is 100 and not some higher n7mber?
While I‘m sure Ben wrote that and I respect his knowledge of pools, how would that work?From Pool Doc (Ben) on another respected forum (now sadly inactive):
Mix 1/4 cup pool water with 1/4 distilled water (must be distilled water!). If FC is really high (didn’t say what would be considered really high), mix 1/4 cup pool water 1/2 cup distilled water. Test the mixture as you normally do.
Sorry, but you can't dilute for pH, maybe that's why The Pool Doc is defunct!While I don’t know the chemistry behind it, certainly it would be easy to test to see if it works?
I have been searching around in the forum, and I found the following old post from "ChemGeek", which says that the distilled water can be used to dilute, and it won't affect the PH reading. What do y'all think?While I‘m sure Ben wrote that and I respect his knowledge of pools, how would that work?
Pure distilled water should have a pH of 7.0, but may not always. If you pH was 8.0 and you mixed that pool water with and equal amount of distilled water at 7.0 is the test going to read 8.0? I can’t see how it would.
If I may ask: what downside is there to lowering the CYA?
In the time this entire conversation has been going on the CYA level could have been corrected though water exchange and operational FC levels lowered to where it is a non-issue.
Running your CYA at 100 means $$$, too.I will need to get someone to do this for me, and that means $$.
Why does someone have to do it for you?Not so easy.
I would like to find a way to check PH with this CYA level until spring. Then I will have to get someone to help me drain/refill.
OMG, I feel like I am back in high school Chem class (which I almost failed!!). I don't understand the science, but I can try it with and without dilution and see what results.
Taylor Technologies does not recommend dilution of pH samples ...
When testing pH, a dilution is not the answer since the introduction of different water, likely with a different pH, will produce inaccurate results.
