There are a few methods to test CH with a Taylor 2006 test kit.
From Tayor's manual:
Calcium Hardness Test
1. Rinse and fill large comparator tube to 25 mL mark with water to be tested.*
2. Add 20 drops R-0010. Swirl to mix.
3. Add 5 drops R-0011L. Swirl to mix. If calcium hardness is present, sample will turn red.
4. Add R-0012 dropwise. After each drop, count and swirl to mix until color changes from red to blue.
5. Multiply drops in Step 4 by 10. Record as parts per million (ppm) calcium hardness as calcium carbonate.
*When high CH is anticipated, this procedure may be used: Use 10 mL sample, 10 drops R-0010, 3 drops R-0011L, and multiply drops in Step 4 by 25.
If you use the 10mL sample, you will use less reagent.
