Long story short my pool (in new house) turned bright green. I had a pool company come to service it as i had no time to deal with it while moving in. They had to rebuild my filter since it apparently cracked (claimed because it was so dirty), and the skimmer lines are clogged up, running only at about 50-75%. Guy said its because when i pulled out and cleaned skmimer baskets i did not reach all the way down and clean out the hole. We had tons of needles coming through as well as some saw dust from cutting down 2 trees.
They shocked the pool, added chemicals and rebuilt filter and it is crystal clear. On sunday the test chlorine was at 5ppm. Guy said to add chlorine tabs to skimmer lines and to floaters and that should be good. i just tested the pool with the TF-100 and here are my findings:
FC: 1.5
CC: 0
CA Hardness: 400 or 450 (turned purplish at 400, blue at 450)
Total Alkalinity: 120
CYA: looks like 70 - possibly even higher
The daily tests were:
Chlorine: about 1, maybe a bit higher
PH 7.2
The pool guy insisted tabs are sufficient, but i know folks here like to pour in bleach/chlorine (such as Shop Pool Essentials 1-Gallon Liquid Pool Chlorine at Lowes.com)
What can i/should i do to get teh FC and regular chlorine up and staying up. Also - anything i can do to get CYA lower?
Thanks all
FC: 1.5
CC: 0
PH 7.2
Thanks all
