Tester request (Excel)
needsajet
5,392
Sydney, NSW, Australia
Hello, just hoping someone will test a couple Excel files for me.
There are two links, and you should be able to download each file. First is the old Excel version (xls) and the second is the newer version (xlsx). If you could just try entering in the white cells (should work) and then in a blue cell (should not let you), I would very much appreciate it :)
Thanks in advance if you're able to
Cheers
TFP test file.xls - Google Drive
TFP test file.xlsx - Google Drive
jet,
I tried, but not sure what I an looking for..
It appears the white cells under degrees F have formulas in them, but it allowed me to enter new data
Lbs. per hour white cells let me enter data...
All the blue cells say they are protected..
I just did the old file..
The xlsx file worked the same way...
Thanks, Jim.
Yep, that sounds right and is all I needed for the old file version. The white cells are meant to be change-able and the results in blue are protected.
Much appreciated!
and thanks for testing the xlsx as well :)
