- Mar 2, 2020
- 36
- Vinyl
- Pentair Intellichlor IC-40
Don’t add a thing except 5ppm of chlorine a day until the kit arrives. That test is just unreliable and anything you do based off of it will have to be undone.Any recommendations so I can get a head start on this?
That is adding 1.9ppm FC to the water each day. For this time of year, that is on the low side. So be very careful of your FC dropping too low. Without a test kit, I would err on the high side for FC.Should I still keep the swg at 50%? I have the pump on 9pm to 9am timer which means swg runs for 6 hours.
I will keep an eye on it. How can I calculate the swg output (hour / percentage / ppm)?That is adding 1.9ppm FC to the water each day. For this time of year, that is on the low side. So be very careful of your FC dropping too low. Without a test kit, I would err on the high side for FC.
PoolMathI will keep an eye on it. How can I calculate the swg output (hour / percentage / ppm)?
