Test results
Paul NJ908
36
New Jersey
Pentair Intellichlor IC-40
Waiting on TF100 kit to arrive and went to Leslies to have the water tested. Any recommendations so I can get a head start on this? Added 1 gallon of instant conditioner after this test.
Don’t add a thing except 5ppm of chlorine a day until the kit arrives. That test is just unreliable and anything you do based off of it will have to be undone.
Several things, like CYA, calcium and salt can only be undone by draining, and usually a bunch.
Reactions: Homebrewale
Should I still keep the swg at 50%? I have the pump on 9pm to 9am timer which means swg runs for 6 hours.
That is adding 1.9ppm FC to the water each day. For this time of year, that is on the low side. So be very careful of your FC dropping too low. Without a test kit, I would err on the high side for FC.
I will keep an eye on it. How can I calculate the swg output (hour / percentage / ppm)?
Also, it appears I’m having DE media returning to the pool. Yesterday I cleaned out the filter cartridges, checked all the connectors, and the rubber gasket on the filter for damage and found nothing. Ran the pump overnight without reintroducing new DE and this is how it looks this morning.C0C88818-3459-4B71-AE49-33788122FFFD.jpegC6ECEDE9-D097-48FD-8E06-01713A9298CC.jpeg
