Thanks for the recommendations... SV was building up a lot while I was out was there. I am sure it has grown even more. At times I wish I stayed there after I getting out of the military. You must have been there the same time I was stationed there.
I did run through some tests this pm. Here is what I am looking at now.
Quick Tests
CHL = 5+
pH = 7.2
Detailed Tests
CDT = Turned pink; 10 drops (871) = FC of 5ppm; 5 drops (003) slight pink; 1 drop (871) = clear; CC = .5ppm... TC = 5 + .5 = 5.5ppm
CHT = Turned Pink = Calcium; 5 drops (11); 5 drops (R12) = 125ppm
TAT = Turned Green; 7 drops (9) = 70 TTA
CYA = 30
My pH went up to 7.2, which is good
My CDT went lower 5.5, which is good
CHT went from 200ppm down to 125ppm, which seems a bit low
TA went from 100 to 70, which is good
CYA went up from 25 to 30 which is good.
So it looks like my numbers are getting more in line with the SLAM recommendations.
I need to boost the pH up a bit to 7.5. So I will throw in a bit more Borax.
Then recheck the numbers tomorrow. At which point if the numbers stay relatively the same, I would need to boost my TA up just a tad and my CH up a bit more.
Thanks again everyone for your help in working this with me. Much appreciated.
